Wonderware Intouch license error ruturn code:-31
duydong3000
Oct 2014
Vung Tau
please help me check problem detail as below
I've replace hard disk and un-ghost and then it's show error after reboot my computer
"An error occurred reading the feature line "IOServer" in the license file C:\program files\common Files\ArchestrA\License\wwsuitelic ( Return Code: -31)
https://insource.mindtouch.us/Suppo...the_feature_line_InTouch_...._return_code_-31
Problem
Trying to open InTouch on a system that has been working in the past. When it comes up it gives an error occurred reading the feature line InTouch[...](Return code: -31). Why is this happening?
Product Version: 8.02
OS: Win 2003
OS_SP: SP1
Solution
The error -31 will typicall occur if the system clock has been modified. User confirmed that when looking at the system clock the year that was shown was incorrect. Once corrected the software would not open correctly.
Close Date: 2013-08-19 08:42:17
My Hard disk has problem and i try un-ghost again to new hard disk and first time running ok, but i turn off computer and un-ghost another hard disk
WonderWare Licence
Same issue system clock was 11 years and 1 week off. Corrected and licence works fine again after system restore. Thanks!
Hello, I really need help. I have Intouch 2012 R2 and already have the wwsuite & archestra.lic on it. when I copied that license on the...
7,349
Hullo, I needed some help Does anyone have some wwsuite.lic or license for Wonderware InTouch 10.1? I really appreciate if you can share it with...
4,588
How to get 30 days demo license of InTouch 2014 R2. Please help. If anyone has got it please share with me.
6,042
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
152
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
163
