Wonderware SQL database error
userxyz
May 2002
any
2,768
Okay...
I cannot start-up the SQL database...
In the errorlog I get =>
2010-06-09 10:40:54.57 server Copyright (C) 1988-2002 Microsoft Corporation.
2010-06-09 10:40:54.57 server Tous droits réservés.
2010-06-09 10:40:54.57 server ID du processeur serveur = 3092.
2010-06-09 10:40:54.59 server Enregistrement de messages SQL Server dans le fichier « C:\Program Files\Microsoft SQL Server\MSSQL\LOG\ERRORLOG ».
2010-06-09 10:40:54.59 server SQL Server démarre à la classe de priorité « normal »(2 CPUs détecté).
2010-06-09 10:40:54.81 server SQL Server configuré pour le traitement du mode thread.
2010-06-09 10:40:54.81 server Utilisation de dynamic verrous alloués. [500] Blocs de verrous, [1000] Blocs propriétaires de verrous.
2010-06-09 10:40:54.84 spid3 Démarrage de la base de données « master ».
2010-06-09 10:40:54.95 spid3 Erreur : 9003, Gravité : 20, État : 1.
2010-06-09 10:40:54.95 spid3 Impossible de restaurer la base de données master. Sortie.
The machine it's software is written in French.
English:
Error : 9003, Gravité : 20, State : 1
I googled it.. I found a lot of forums and posts... some forums say to try Rebuild.exe, but that file doesn't exsist. The problem will be a corrupted mdf file... but we do not have backups. I now have the idea to reïnstall the SQL server or to update it... it's MSDE. I have no idea if it will help.
Anyone who knows how to get this SQL server running again ?
Thanks i forward,
Regards,
Gerry
For working out current condition you can try sql mdf recovery. It owns some effective capabilities such as working under any system requirements. Using modern methods of restoring and clear interface for any experienced users...
Hello mutu26, you might want to check the date of the original post before your next reply.
Hopefully, Gerry got an answer in the last 15 months since he posted!
Paul
Hello everyone, I am developping an application and i want to be able to consult the info in a certain period of time. For example ÁreaX...
3,775
Hi all, I have installed both WinCC and Wonderware in my system and its respective database with it. but i am facing some problem in opening a...
5,366
1. Why Wonderware crash after SQL crashes. Can I get something official of AVEVA?
1,052
I’m trying to get data from a column in sql server to post in wonderware. My select script is as follows...
4,546
I have a wonderware standalone HMI collecting process data from our production line. I am writing those values to a database in MySQL, though I...
2,746
