work in -20 degree
abbastukanov
Jan 2017
konya
hello everyone. in our project we need to use analog laser distance sensors and laser field scanner in -20 even -30 degree on moving crane. sensors working in -20 degree are very expensive and field scanner which we found works in min. -10 degree. What do you suggest how we can give a warm that all devices work normally? Thanks for your helps.
I have an application using an incremental encoder and then I convert it to degree (0-360) using calculation program. For a while, the calculation...
309
Good Evening , Do you folks know of any Electric Actuaters that can handle about 180 Degrees F ? What are the common brands of Actuaters ...
1,138
Hi All, I am currently working with an Inclinometer that ranges for 0-360 angle degrees single axis (0.1-4.9 Volts). Is there a conversion...
1,101
Hello guys, Induction oven heater inverter failed. we replaced it by vacon nxp 160kw type inverter.it is working fine but our problem is oven...
2,382
Hi, I am trying to figure out what Pollution Degree our control panels must meet. FYI, this is one of the informations that MUST be labelled in...
1,496
