Wring to DTA100's
wvos
Oct 2011
veghel
Hello,
Couple days ago i asked some question about a whole system but i sort off figured most of it out. Im working with an IFM AC1305, 2x IFM DTA100 ( RFID Write/Read heads ) and a bunch of IFM E80318 ( RFID Tags ) and finally my CPU is a 414 2 DP one from siemens.
Im trying to read the data on the RFID Tags in my Step 7 program and that works just fine. The writing is an issue tho. Ive got my hardware config set up so it reads the input words 568 - 583. The first DTA100 is read in Input word 568 and the second one in Input word 576. They both receive the decimal value 125 ( A default i assume ).
Now the issue is writing to the RFID tags. Ive got my Output words 572 - 595. Whatever i put into those words i cant seem to read anything other than the default in the RFID Tags.
My question is: What do i need to do to write anything in the RFID Tags? I know about a command channel but i cant seem to figure out if i need to change a mode to enable writing.
I attached the Hardware Config of my system for better understanding.
Hello,
bump
Hi, did anyone worked with IFM DTA100 RFID system on Step7 ??? I'm looking for some examples and all I found is some document in German. Is there...
3,738
