Writing to values in a string array - Logix 5000 - offline
radfahrer
Nov 2006
Boston
156
Does anyone know of a way to set the values of strings in a string array in a Logix5000 program when offline (before connecting to a PLC) so when it gets downloaded, the values are ready to go.
We're looking to make some generic alarm and I/O screens on our HMI, so we want all the tag names and descriptors to come from String tags in the PLC, but we don't want to have to manually type them all into the PLC.
I've seen several posts on using DDE, etc. from Excel...but from what I can tell, those all require an on-line connection to a PLC. I'm looking for a way to do it directly into the offline file tag config. before I have access to the physical PLC. I'm at the home office, the PLC is at the panel vendor being assembled, so I'm looking to get the file ready for download ahead of time.
From what I've seen of the the Tag/Import export tool, it doesn't allow setting tag values, just tag configuration. And the Upload/Download Tool is an on-line tool as well, like DDE, so doesn't help me with this.
Any ideas are greatly appreciated.
-G
Create your tags and save your project in the L5K format. You can change the data there and re-open. But if you don't have a lot of tags, the editor in RSL5K is not bad.
Does anyone have a vb app to write string values to tags in an RSL5K program while offline? I worked with a guy once who had written one that...
4,205
In the Allen Bradley alternate reality program logic and program data are linked together. Is it possible to update a Micro Logix program with out...
4,448
I am using Wonderware as a SCADA host, and am using messaging to read data from ML1100's to a CompactLogix L30ER. I have been experimenting with...
2,226
hello all, I was wondering if there were anyway to write values to my plc micrologix 1000 from the HMI using the advancedhmi software nad not my...
4,316
Hi, I am designing an HMI with Workbench for a Micro1400 PLC. I have a PLC variable that manages the "states" depending on the integer value of...
1,263
