Writing Wonderware array values to Controllogix array values
JHOGGINS
Jun 2006
Tauranga
Hi Thanks for reading this post. I Having trouble writing Wonderware array values to a compactlogix PAC.
I can read the values through a String Array through using the scripting described in Wonderware’s tech note:808 But when it comes two writing the values from the array .They are not getting passed through to the OPC client or through to the PLC.
Being Recipe values they will not need to be accessed regally or quickly I have tried a few “for next” Scripted loops without success. Any Suggestions?
I didn't think wonderware supported arrays, IO or memory.
There are ways to achieve it, but is not arrays in the pure form.', as i understsnd them anyway.
System Platform has arrays, but would need to check if they can be linked to IO.
How are you reading/trying to write?
Hi all, Currently delving into Wonderware/Aveva System Platform for the first time, and I'm trying to set up a script to automatically write to...
944
Hi, I'm designing an HMI using the Wonderware Archestra IDE (2017) and I'm trying to figure out the best way to use a user input to pass a value...
2,663
I am using Wonderware as a SCADA host, and am using messaging to read data from ML1100's to a CompactLogix L30ER. I have been experimenting with...
2,237
Wonderware Intouch, Kepware timing issue with "simultaneous" writing of many tags I have an Intouch application coupled with Kepware that is...
17
7,250
I am using Wonderware Intouch 2012R2 Classic. I confugured Alarm DB Logger Manager to run as Normal Application as i am also running Wonderware on...
6,689
