Xmas 2018 Puzzle (2)
L D[AR2P#0.0]
Nov 2006
UK
6,694
Shown below is a simple magic square where the 3 columns, 3 rows and 2 diagonals add up to 72.
Convert it to a multiplying magic square in which the numbers in all 8 lines if multiplied together give the same product in every case. You are not allowed to change or add to any of the
figures in a cell or use any arithmetic signs but you may
shift the two figures within the cell - for example you
may write 27 as 72
Divide a circular field into 4 equal parts using three fences of identical length. As this answer is pictorial, PM me the length of the fences...
2,634
Seven PLC vendors are selling 1MB memory cards. The respective stocks held by each vendor are: 20, 40, 60, 80, 100, 120 and 140 memory cards...
33
7,753
I came across this old chestnut recently and thought I'd post it. A PLC project involving structured text (ST), function block diagram (FBD)...
2,666
I am preparing an Xmas puzzle and need a tester with access to TIA V15 - contact me via PM.
2,883
No solutions posted so re-running this one from 2017 http://www.plctalk.net/qanda/showpost.php?p=760646&postcount=1
1,631
