XT-EX 1756-L7x ESM Questions
Honga
May 2010
Aus
316
Being an amateur I was pondering upon the use of the ESM in hazardous environments. I've been told that they're well desired in mining.
I suppose this is generated from the release of the L7x.
But as for the explanation I cannot figure it. Wouldn't you rather a battery because the current is internally restricted, whereas a supercap would more likely generate an arc?
After all, our product requires that all caps have leaking resistors installed prior to sending to our mining customers.
Hi to All, I have a 1756-L7x redundant processor in one VLAN gateway is 10.17.120.1 and 1734-AENT in another VLAN gateway is 10.17.130.1, subnet...
3,984
Having heard about the Intel quad core in the new L8 series processors, I was eager to get a new project where I could use one. That day came and...
17
12,627
I'm checking on somebody else's very first PLC5 to CLX program conversion for them and noticed most integer tags were kept as INT rather than...
1,991
Hi all I have a ControlLogix 1756-L71SP that i want to use for general PLC applications, not safety. I am running Studio5000 v33, i can't...
64
361
