Yaskawa Ethernet drive and Micro850 or 1100
geniusintraining
Jun 2005
SC
8,278
I have a customer that has a Yaskawa Compact Vector v1000 with Ethernet, they want to add speed control and a barcode reader and speedup, slowdown, stop, etc., they will be building one at first then a few more
I saw the tech note for a Compactlogix or Controllogix but they are wanting to use a Micro850 or ML 1100
Anyone ever control a Yaskawa v1000 with either one of these? I will keep searching but not finding much, I did find some Modbus but I think they will be Ethernet IP... or is the drive Modbus ?
Mark
Thank you, looks like I need to see what "optional" modules they have install if any on the drive
I don't know that I can help, but I just finished building a simple ladder in CCW (micro820) that communicates with a Schneider Atv630 drive using Modbus-TCP.
I would assume the communication would actually be the same just maybe different addressing structure and the drive would probably be setup differently.
I can control and read out any of the Drive Parameters (About 1729 different settings) through the PLC which I have a HMI setup just to make is simple for the user. All user has to do is tap "Set Speed" change the Hz and drive will RAMP to whatever speed has been set.
I have attached a screen shot of the HMI screen.
I must say it works very well!!
Hi, I am trying to see if I can connect an Omron CJ2M-CPU32 PLC to a A1000 Yaskawa drive. My Yaskawa sales rep says yes with the addition of an...
2,496
Guys, I have built a system with this servo indexer and am using the built-in PLC. It has a RedLion G3 running with EIP and a Phoenix EIP bus...
5,013
Anyone have any examples of controlling a Yaskawa F7 drive over EtherNet from a ControlLogix via the CM092 option card?
3,120
Hello, We are having trouble setting up a generic ethernet module for a Yaskawa GA80U4168 drive in RSLogix 5000 Version 20.01. All of the...
616
Hello all Has anyone created a generic eds to talk to a YRC1000? I've set the robot the produce/consume 20 bytes and have used a generic eds...
2,177
