Yokogawa Centum CS3000 Comms
Jan 2003
Michigan
490
Hey all. A customer has asked me to pull two data points from an existing yokogawa centum cs3000 dcs to a wonderware system. I dont know which revision the CS is, but I would wager its 10 plus years old. Does anyone know what comms the yokogawa uses? Currently the wonderware system is all ethernet based on ethernet/IP and modbus tcp. Is this something I can comm to easily or should I just spin a cheap PLC at these two data points (temp and weight) to collect them and ignore the yokogawa all together. Thanks
matt
If you have an OPC server running on the DCS network (for Exaquantum or PI) you should be able to use the OPC driver that comes on the WonderWare Device integration disc to communicate to the Yokogawa OPC server.
Simulation of centum3000 offline
Hi, i´m new in this post....
I wonder if someone has made off-line simulation with DCS?
I need your help please is urgent....
I need to build a CENTUM CS3000 system for simulation. I couldn't find any guide or manual on how to build such a system. I found the following...
1,623
Hi, i want to construct a full DCS project using yokogawa Centum CS3000 anyone have some materials,manuals help me. Regards.
4,755
3,085
I am investigating the possibility of virtualising a Centum HIS station in vmware. Assuming i can successfully install a Vnet\ip card in the...
1,667
hi everyone, I am working on yokogawa centum vp r5 DCS installed at some plant in my Pakistan. I have the following issue kindly help me out if...
1,952
