yokogawa controller with modbus tcp/ip communication with s7 1200 plc
georgevjoel
Jan 2024
kerala
can i send and recieve data using my yokogawa UT35A controller with my siemens s7 1200 plc using profinet communication without using gsd file
You need a GSD file for anything that doesn't appear in the hardware catalogue on TIA portal.
Does it have Profinet though? It says Ethernet and Profibus but doesn't actually specify that Profinet is an option.
RS-485, Ethernet, PROFIBUS-DP, CC-Link, DeviceNet
On page 1-8 of the user manual it says that the Ethernet port can be used for Modbus TCP which you won't need any additional hardware for. Profibus and Modbus RTU would both need communication modules.
I need modbus communication tool for Yokogawa Rotamass Flow meter? can any one help me.
984
Hi, i'm working with a differential pressure transmitter yokogawa EJA130E and have problems to connect it to a Schneider analog module TM3AI4...
2,066
Hi All, I'm currently working on Vulnerability signature of ICS software and i'm need of few Yokogawa software. The need is only setup file...
1,749
we have Fast/Tools at Control room to monitoring oil wells (RTU STARDOM) the Media Communication was CDMA Modem , Now we want to use the Wi-Fi...
1,095
hi all : I need software drive yokogawa Vnet/Vnet adapter , working at windows xp sp2 ..... thanks .
1,371
