Zoom in
nicksmick
Feb 2015
Dallas TX
I am NOT asking this because my age might be affecting my vision or anything like that... but, is there a keyboard shortcut (hotkey, quick-key) for zoom in and zoom out in RSLOGIX?
Gets aggravating having to click view, click zoom in three times to see which bracket I mis-typed in a formula. Then click view, click zoom out three times to see my whole rung of logic.
In studio5000, holding CTRL and using the mouse wheel will zoom in and out. Not sure if that is the same in Logix5000, and I would be surprised if it was the case in logix 500, but worth a shot.
Also, CTRL and the "+" and "-" key on the keyboard might work.
have you tried the little "Plus" and "Minus" magnifying glass icons at the top of the screen? ...
personally I do most of my "formula typing" in Notepad (etc.) and then Copy and Paste it into the editor ... that way I have more control over the font being used - which makes it easier to get things right ...
same thing for when the entry field is only wide enough to see a small part of a long tagname entry ... Copying and Pasting into and out-of Notepad helps eliminate the "peeping through a keyhole" effect while scrolling back and forth to read the entire tagname ...
there's also a "Toggle the Controller Organizer" icon up near the top ... that one easily pops the window on the left in and out of view - which quickly frees up more space for your rungs ...
My problem is that I'm using a laptop. It has a touch pad for a mouse. So no scroll wheel. It has no + or - keys without using shift. I do toggle the "controller organizer" off. But to tell if I mis-typed a squiggly bracket when I was supposed to do a square bracket, or if that is a 1 or an I... I need some zoom!
The Logix 5000 keyboard actions for zooming are:
Alt+V (then) I (to zoom in)
Alt+V (then) O (to zoom out)
These are keyboard controls for conventional Windows application menu access. I have not found a method to define custom shortcuts within Logix 5000, though have not looked too hard.
Nick> My problem is that I'm using a laptop. It has a touch pad for a mouse. So no scroll wheel.
Nick,
You might try plugging a USB mouse with a scroll wheel into the USB port.
MadPoet.
For logix i just go into Jedi mode, instead of straining my eyes finding the error on screen or battling with keyboard layout/language. Should I need a magnifier I would look into third party or windows.
Hello, I am working on a SCADA system using Wonderware Intouch 2014 R2 and have a small glitch with the historical trend feature. Every time I...
2,880
Hi, ive been working with Factory Talk View for over 3 years now. ive completed many projects and ive always asked myself this one question.. Is...
2,287
Is there a way to zoom in, in Simatic Manager? I have an extremely high resolution monitor (3200x1800) and it's hard to read. I know that I can...
2,449
in omron nb10 xy plot is zoom with this function..i want to zoom xy plot.it is possible in nd10w-tw01b.please help me
1,463
Hi guys I have Productivity Station which will collect Run time data from Phoenix input block "ILB ETH 24 DI16 DIO16-2TX". I am new to crimson...
2,927
