Delta HMI screen Freezes out with Delta PLC at intervals.
okoye
Jan 2010
lagos
32
Hi great Friends.
I used a Delta HMI (DOP-B) series connect to a Delta PLC (DVP- EH) model....both hooked up on a wire drawing machine. Both of the HMI and .PLC have been working fine over the years until lately.
The HMI now freezes its screen at different intervals during operation. When this happens, machine stops and all the control icons on the HMI no longer respond to human touch.
The machine only comes on again after an Emergency button is pushed OR after Powering off and on again.
(1) What is responsible for this intermittent FREEZING of the HMI...?
(2) What is the easiest way to solve this intermittent problem...?
Note: there is no BACKUP program for both HMI and PLC.... because the machine is a bit old.
Hi.. I want the delta hmi configuration software Screen editor V1.05.81. I think this is the only version, in which Delta DOP-AS57CSTD model is...
4,895
Hello I am new to programming HMI Delta with plc delta , but i wanted to do simple programming to view at power up the starting screen as logo for...
6,331
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
38
Hi, We have a customer that has an old DOP-A80THTD1 that is needed to be upgraded Can we upload from these units? Is there a special...
95
Hello, I know little English, I want to use 4 plc cqm1 as slave (modbus), and hmi delta as master. Unfortunately, I cannot establish rs485...
584
