I have a Ozone Monitor with a 4-20mA output. The scaling for the O3 Monitor is 0 to 2.0 PPM, so 0 PPM = 4mA and 2.0 PPM = 20mA.......right? The problem I am having is when connect to an AD DL06 with 4 ch analog IN card it reads full scale (digital display reads 0 PPM)....4095 EU's. I spoke with their tech service guy he said to put a 1K Resistor between the two wires and check with a Multimeter. I am getting 130mA. I have also hooked the 4-20 out to a Micron Panel meter, it starts flashing and the numbers jump around. So, I called thier tech support again, this time I passed on to an engineer. He said that it is a common problem for prople to get incorrct reading from their O3 Monitor because it is a Current Sourcing Device and the meters or PLc have to be set up for this type of signal compaired to most 4-20 signals being passive. Does this make anysense to anyone...... I am lost need some help.
thanks,
Micheal
thanks,
Micheal
