RSLogix 500 Ladder Logic Window Size
RSLogix 5, 500 and 5000s user preferences and screen settings are stored in the Windows Registry. But, you don't have to edit the Registry to reset them.
Just start RSLogix with CTRL and SHIFT keys held down. Be sure to hold them down until RSLogix has finished opening. To find out if it actually cleared the registry entries, check the FILE menu to see if the 'Recent File' history is cleared. If so, you know this has worked and you can test your RSLogix software again to see if any screen problems remain.
Windows should remember "not maximized" screen size
The following tip should work,no matter how RSLogix is opened
from Ron Beaufort
"for open up with max screen: open rslogix500 - use restore button to make it NOT maximized - then stretch and resize the window manually to make it as big as possible - then do "window" - "arrange" to fix the toolbars and the project to fill screen - then maximize the rslogix500 window - then do "window" - "arrange" again - now shut down rslogix - make sure your icon is set to run maximized -
now it should open up full screen from now on - unless i left something out"
wildcatherder is right!!!
It is still not maximized, but screen is big how I set it, thanks very much.
I don't know, why we paying so much money for this user unfriendly software.
So I very much new to doing ladder coding I have a pump with a Stop float switch that stops the pump when a sump is low. I want my manual run mode...
1,393
How can I achieve the same functionality in Studio 5000? Image 001.png for the old RSLogix500 program Image 002.png for conversion to Studio...
2,529
I had an idea to improve some of my standard programs, and make them easier to modify/expand in the future. Is there a way to address the current...
3,687
Hello all, I have been in the maintenance field for about six years now, and I work around many machines running with the SLC 5/03 and 5/04. We...
35
9,050
Hello, I am having some problems and I am wondering if I can get some guidance. I will explain the process I am trying to achieve. I am trying to...
4,108
