Hi All,
Just if anyone is following this thread, here is the solution that I have come up with...
To recap on what I was trying to do, I had 30 products that ran down a production line, with about 50 odd variables for each product. I was trying to avoid creating 30 pages (ie one page for each product, with 50 different variable tags on each page).
I found the function SET(Tag, Value).
So from the source page, if I wanted to edit Product 1, I had the following "complex" code tied to a button
Set(Product_Edit.Product_No_Select_For_Edit,
1);GotoPage(Product_Edit);
The code for Product 2 button was then
2);GotoPage(Product_Edit);
Then I had code in the PLC which checked for a change in the Value of the tag "Product_No_Select_For_Edit".
If a value was other than 1, then load the tags for the Product (eg Product[n]) into the Editing Array.
I then used another button to save the changes from the Editing Array back to the Product[n] array..
I will get around to documenting this a bit later on...
Each product is part of an array of called Product.
The array uses a UDT, which then has the 50 or so variables underneath it.
So far this seems to work ok.
Let me know if I have not explained this well enough.
Thanks guys for your comments
