Siemens S7-300 to Omron CJ2M
MSutton
Sep 2015
Birmingham
I want to connect a S7-315 cpu to an Omron CJ2M via Ethernet I/P and transfer mainly bit data ie. turn an Omron output on from the S7-315 or turn a s7 output on from the Omron. Is it possible?
Hi Guys, I have a 2x Omron FQ cameras with a Touch finder panel, inspecting eye drop bottles on high speed conveyor interfacing with Siemens S7...
4,370
Hello all. I have an ESA HMI that is connected to a Simatic S7-300 (CPU312). I have uploaded the program from the PLC which is written with Step7...
1,447
Hello. There is a problem with Siemens S7 300. We got a replacement PLC but it does not run the program from the MMC. The new PLC is dated 2011...
689
Hi to all, Our company does not usually use Siemens PLCs, but have a press with one in it. We are trying to change the IP address in our Simatic...
1,066
G'day guys, I am setting up a s7-300 as a test rig for the workshop and when I downloaded the PLC is not going into run mode, I keep getting a...
35
5,220
