iFix Migration question(s)
Malador
Jan 2012
Pacific Northwest
60
Whats the best way to move iFix from a Server2008R2 machine to windows 10? The hardware is identical on both machines. Both are running iFix5.8
I thought it was as simple as installing iFix on the new computer and moving the PDB, PIC, and Local folder. But i get a black screen when i start ifix. I also can't accesses security in the SCU. Same windows user name on new/old machine.
Should I have used the backup/restore utility? I'd give it a try, but i won't be on the site with the current server for a couple weeks.
I done a few of these lately. You are doing the right steps, as far as I can remember. Even GE doesn't recommend using the Backup/Restore for upgrading.
I think it's security that's messing you up. I do remember something about disable security on the old machine then do the copy and paste.
Ok, I found some old notes. First, you need 5.8 SP2 per here:
https://digitalsupport.ge.com/en_US/Article/Supported-Operating-Systems-for-FIX32-and-iFIX
2nd, from my notes, you can probably skip over some of these:
*create a new SCU from scratch, take note from the old SCU file.
-. on existing system, disable security in SCU.
-. Report out security to Security.RPT - under file-Export and copy it
- re-enable security on existing system.
- on new machine, import the security file in the new SCU. Enable security.
Not just iFix, but for other also, I have put VMWare Converter on the server PC, make a VM clone & put it on an USB hard drive.
On the Win10 PC put VMWare player {free}, copy the Server VM to the hard drive, open Player & locate Server VM. When it opens MAKE SURE you select you MOVED the VM and it will open. {If you select COPIED IT Player will create a new VM based on it & you may lose licensing}
Keep an archive of the VM on your network server for any future need to replace.
Also, in the VM make sure the iFix dongle{s} are attached to the VM & not the host PC.
Thanks for the tip. In the past I've used imaging/back up software to install a sever copy on a VM, but Rockwell licenses sometimes get messed up. This sounds much easier!
Has anyone successfully migrated an older Proficy/ iFix Historian database into a new FactoryTalk Historian server? Trying to eliminate having two...
1,169
Hello. Dose anyone know about iFIX? Please help me if you know. Recently we updated iFIX version3.5 to 5.5. After updating, network speed have...
1,847
Hey guys just curious if any one has been involved with Ifix to Factory talk migration. I have close to thousand Tags in Ifix that I am trying to...
3,313
Hello, I wish to use the Historical Pen Group Export Utility followed by the Historical Pen Group Convert Utility, however I am missing the...
3,537
53
