AB Micro 820: Two Modbus Networks at same time? RTU Master, TCP Slave
AutomationTechBrian
Jul 2013
St. Cloud, MN
669
I successfully got a Micro 820 (Slave) and Red Lion HMI (Master) to work together using Modbus TCP. But now I need to add an Automation Direct Solo Temperature Controller to the PLC, which uses Modbus RTU. I don't mind the learning curve, but part of me wonders if the Micro can be a Master on the RTU, and a slave on the TCP at the same time. Anybody able to offer some experience on this?
Yeah, I worked on it last night and I'm getting the feeling it's not a problem. What *is* a problem is figuring out how to set it up. I've done a little bit with Modbus, but it seems like there are a bunch of different ways to do Modbus communication, depending on the manufacturer. Garry Shortt has a fantastic video for setting this up using an Automation Direct BRX PLC. I have one sitting around, so I did that lab first.
https://www.youtube.com/watch?v=PndrIfBImGQ&t=504s
But now I'm looking at duplicating that in CCW, and it isn't obvious how to accomplish the same thing... although I just saw something in the manual that could be helpful. Maybe coming back to it later today might make things more obvious. I guess just getting a successful read of the PV first would be good, and then build on that.
I'm heading out the door to do some service calls. I'll look at this later on tonight.
I’m running a micro 820 to measure a tank level, then turning on equipment at certain levels. I have an analog input (4-20) that I’m storing and...
279
Hi All, I came up with this for ramping the PWM pin on the micro 820. I'm new to ladder logic so I am not sure if this will even work? Once...
350
The micro 820 is visible in RS Who when I configure my Ethernet to capture the random IP. I am getting an error when following the steps below...
952
Hi! I need help converting an old MicroLogix 1100 project to Micro 820. Project Details I have an old MicroLogix 1100 program that has been in...
473
