Ron Beaufort
from tomalbright:
well, OK, Tom ... the problem is that I still don’t see the “half” where I was “wrong” ...
for one (minor) thing, the manual that you linked is for the “Classic” PLC-5 processors ... but the PLC-5/11 is an “Enhanced” type ... so a better manual to use would be the User Manual for Enhanced and Ethernet PLC-5 Programmable Controllers ... but that still doesn’t change things ... even in the manual that you linked, on page 4-12 it says this:
and that rule (I’m quite sure) holds true even for the enhanced processors ... the way I see it, you’re trying to use “complementary” addressing for mholt’s system ... but the fact is that he only has TWO chassis - and one of those is the “processor resident local” chassis ... and you can’t set that one up as “complementary” ... and ... even if you COULD, that chassis is NOT going to be assigned as “Rack 03” ... and THAT presents an insurmountable problem - because any Remote I/O connected to a PLC-5/11 MUST be assigned as “Rack 03” ... and ... the only way to “complement” two I/O chassis is to give both of them the same “rack” address ... oops! ...
and so, we can’t get there from here ... specifically, the “local” chassis can NOT be “Rack 03” - but the “remote” chassis MUST be “Rack 03” ... this is one reason why the two chassis can NOT be set up for complementary addressing ...
I’m still not sure what you mean by the rest of your statements in Post #15 ... but I’m willing to bet a LOT more than pocket change that this suggestion isn’t going to work:
I’m convinced that won’t work ... first because mholt’s list only shows TWO modules in that remote chassis - not THREE as you seem to have in mind ... but more importantly, he’s already confirmed the actual addresses for those two modules with this statement in Post #14:
which goes right along with what I forecasted back in Post #7:
now then ... I think that if we leave the “complementary” addressing behind - once and for all - then everything will start making a LOT more sense ... specifically, let’s just have the “local” chassis set up for “two-slot” addressing - with the eight existing 8-point modules tucked into the 8 chassis slots ... and then let’s also just have the “remote” chassis set up for “two-slot” addressing (for consistency) - with the two existing 16-point modules tucked into the first 2 chassis slots ... that should give us something like this:
note that setting up the “I/O Configuration” table is NOT necessary on a PLC-5 system ... but I just did it for “documentation” purposes - to help nail down the ideas involved here ...
anyway ... I’ve devoted as much time to this as I have available for right now ... if I’m “half” wrong, then so be it ... this won’t be the first time ... but ... actually I’m still convinced that I’m totally right ...
that being the case, I’d certainly appreciate it if you could show me where I’m making my mistake ... personally, I’m always ready to learn something new ... that’s what makes this job so much fun ...
party on ...
And Ron, you were half right...
Try the outputs numbered by group address... Use beginning addresses I:030/00 for the first module, I:030/07 for the second, and O:031/00 for the third, etc.
for clarification:
The addresses for the input card are I:030/0-17
The addresses for the output card are O:030/0-17
I was programming on it not to long ago and that is how they are addressed.
the input module should have the following addresses:
I:030/0 through I:030/17 ...
the output module should have the following addresses:
O:030/0 through O:030/17 ...
note that this conflicts with what my colleague tomalbright posted - but I still think that I’m right ...
party on ...
