TEOWK
Good Day!
I am working with a data table manipulation with Siemens PLC S7 300-315 DP. I need to create an application where the data in the data block will be shifted by 1 field to the next field ( DB1.DBW0 move to DB1.DBW1, DB1.DBW1 move to DB1.DBW2 and continue.., previuos data in DB1.DBW0 will be filled with new value) I try to apply pointer p# but failed.
Please kindly advise me on the right method(code) to serve this appilcation.
Thank you.
Best Regards,
Teo WK
Thank you.
Best Regards,
Teo WK
