8 Pin mini Din male connector
Turkish
Oct 2002
NY
Hello,
I'm adding a HMI to a Micrologix 1200 and had intended to make my own cable. I'm not having much luck finding an 8 Pin mini Din male connector to attatch to the processor. I've checked Allied electronics and Newark electronics. They carry 8 Pin mini Din connectors, but they're not the same pin configuration. Hopefully, someone could point me in the right direction.
Thank you.
Turkish
The Doc is right, A-D's cables are the best for the money. Note that the 8-pin end is 90°, which is perfect for a ML1500, but I'm not sure where the keying pin is on a 1200. IOW, which way will the cable exit? 3, 6, 9, or 12 o'clock?
Though not as nice of a fit (see THIS THREAD), a standard Apple cable DOES work. If you're a glutton for punishment (and can solder on the molecular level), Allied sells 8-pin ends from Lumberg (742-1556). An easier solution is the Cinch ones from Allied (750-0234 and 750-0238). These come pre-wired on a length of cable.
beerchug
-Eric
Look a little closer at the mini-DIN receptacle on the Micrologix PLC's and you will notice the flat surface at the six o'clock position. Guess what that says; nay, screams out? You're right: PROPRIETARY!!!
Optimate had to spend about $8k to have the mold made so they could produce cables for their text messenger.
You won't find a plug like this on the open market. Your only solution is to buy one from the HMI manufacturer, if available, or A-B.
If the cable isn't long enough, you can make an extension cable and use a RJ11 cord coupler to hook the two together.
bmac said:
...and use a RJ11 cord coupler to hook the two together
One note about couplers some may not know... There are two types; you need to use a "data coupler" rather than a standard telephone one. The telephone ones invert the wiring... utoh
beerchug
-Eric
Im having to re purpose some old PlantLinc 580 wireless IO extender boxes. Im having a little trouble trying to find a cable for them. The...
2,098
I am looking for 8Pin mini-Din male connectors. To attempt to make my own cables. For FX PLC's the ones I have been seeing the pins are not the...
1,908
Hiii, I want to communicate MGate MB3180 to my ML1400 channel0 configuration as my ML1400 as Modbus RTU master. But i need pin configuration for...
1,744
Hello all, I joined this forum because I saw there was discussion about the 8 Pin Mini DIN connector on Allen Bradley. I am trying to connect...
18
9,941
That is, do all PLCs that use 8 pin mini-din for connection to PG use the same 8 pin mini DIN? In case I'm using non applicable terminology, I...
25
11,260
