driving 7 seg led displays
mpiotro
Aug 2004
Toronto
57
Hi folks,
in my application, I will be using 4x 7 segment led displays.
Hardware is a DL-06 (with appropriate exp i/o).
Now, I was prepared to wire each segment as a separate output, and then utilize the directsoft command for 7 segment displays.
A colleague told me I could reduce the # of outputs required, by using a 7 seg driver. I think I found such a thing here:
-->http://www.marktechopto.com/PDFs/Toshiba/ACF431.pdf
Looking at this, I think the driver works by receiving its input as serial data. Pending what binary# is sent, it then lights up the appropriate segment.
My problem is that I am using port 2 of the plc to communicate with a vb application.
I am not sure if I can use port 1 to send the serial data required by the 7 seg driver.
I guess my question is if there is an easier (not more expensive) way to do this, or have I got the just of the situation.
My gut feel is to skip the driver and just wire the outputs to the segments. There's only 4 (no possibility of more req'd), and the expansion modules for the Dl-06 are quite inexpensive.
Any direction/advice/opinions would be greatly appreciated.
-Mike
shame, shame Mike
Thanks Eric.
This provides me with the info I need, and shows the many ways of skinning this cat.
Geez, Now that you've provided the link, I think I recall seeing this info before...D'Oh!!
Oh well, I could have done worst. I could have put everything in my post in caps and given a deadline of tomorrow ....
-Mike
4 digits by 7 segments = 0-9999 or 10000 Binary or whatever..that's a lot of I/O (like 10). I'm still waiting for a comm. option module for this -06 thing.. I'm currently stuck in a sitiation where I need to communacte with two D0-06s and a modem. Likely will have to use port one of the master for the modem.
What's the communication type/protocol with the VB app? Maybe you can use a small HMI like an EZ text on the same comm bus??
Mike,
I'm still designing this, but I intend to use non-sequence protocol to send/receive ascii strings to and from the vb app.
Yeah, I hear you on the ez text display. I thought about this for awhile, but the only info I need to convey is digits, and I can get nice 1" 7 seg led's from lumex quite cheaply
--> http://www.lumex.com/product.asp?id=1006068
I know the ez text is quite cheap, but you wouldn't believe how scrutinizng the bean counters are here. My time/effort is essentially free. They've got the blinders on for component costs only.....
Mike,
I checked this out on the AD forum. Yes, it is possible to hook up either the DV-1000 display, or one of the optimate ones, while still utilizing port 2 for other interfacing. Both DV-1000 and Optimate connect via port 1, and in my application with the DL06 I'll be using port 2 (ascii in/out) to interface with the vb ap.
I particularily like the DV-1000 solution, as it is programmed all thru the ladder logic (no other software required). This is a nice solution, as I don't need any outputs now for displays, and I can also put text messages as well (not to mention there are programmable keypad buttons).
-Mike
We have a handful of nearly identical flywheel-driven machines. About a year ago, we installed a 15HP Powerflex 525 drive in simple V/Hz mode...
890
Is there any issue with running a VFD-controlled 3-phase induction motor in torque control mode in the braking region continuously (back-driven by...
4,078
Hello everyone, we're trying to get some information from our screwdrivers. - The control chain is IqR plc with RD77MS16, connected to MR-J4 and...
840
Hi All, trying to restore a runtime application that i have been reliably informed was created in version 10 ftview, i get the below error:-...
997
This is the tab order I have in the e-sign component in Rockwell. Is it set in stone can this be modified? The ideal set up would be to get to...
1,293
