Pico inputs?
BDKuhns
Sep 2003
KC, MO
78
Hello everyone! It has been a while since I've been on.
I was hoping that i could get some info on how to connect potentiometers to a Pico PLC in order to control timing of a circuit?
Here is what I am trying to do....
I have an old food vacuum machine that the timing PC board went bad on. Rather than trouble shooting the board, I would rather install a Pico controller to run this operation.
I do not understand how to use the potentiometers for the vacuum time and the seal bar time as analog inputs to this type of controller. The PLC I am thinking of using is a AB-1760.
Does anyone have experience with this unit and can tell be how to use the Pot's as inputs.
I'd like to learn more about the input theory ( analog and digital ). Any suggested reading?
Thanks Barry.
Barry,
Typically, the idea of the potentiometer is to reduce or increase the time it takes to charge a capacitor. Once the capacitor is charged to a voltage that will activate a timer then the timer runs.
In order to use a potentiometer as an input you need to use an analog input on the PLC. This is the Set Point. You need to convert that signal to a time-value. You then need to provide a means to indicate how long the particular condition exists. This can be done with a vacuum sensor. When the vacuum exists, the input turns on. Then you run a timer in the PLC. The timer value is based on the analog input from the potentiometer.
The Pico user manual has a diagram on how to connect a potentiometer:
[attachment]
The problem is that, as far as I know, you can't use the analog value as a timer's preset. You can only use them in comparison instructions... :(
This is why a Pico is called a 'programmable relay' and not a PLC... :nodi:
beerchug
-Eric
ok
Hi Barry I see Eric has addressed the pico. What kind of signal is feeding the old timing pc board? If it is digital = a contact closes then the pc board times out and does something esle. You could use this same signal to the pico and let it do the timing. If it`s an analog signal to the pc board there are some inexpensive controllers that will take analog Crouzet makes one.
http://www.crouzet-usa.com/
Where can one safely download the AB Pico software? What cable is needed to connect to PC?
1,914
Hi im trying to connect my pico to my laptop but I cant configure the com port for usb. it works okay on a different laptop with the serial cable...
2,055
Hello, I am having trouble getting online with an old AB Pico module. I am currently using the 1760-CBL-PM02 cable, and cannot autoconfig via...
1,371
So I’m trying to write a program for a small stand alone press. We had some pico controllers in stock and figured it would take care of what i...
2,725
I wrote a small program the other day (4 inputs, 5 outputs) for a piece of equipment we have. A simple shackle bender with 2 limits, a footswitch...
1,323
