Steve Etter
Hi all.
I have been asked to pull prices together for a very small system where I will have just a few I/O. I am looking for hardware recommendations. I have only a few experiences with very small PLC systems and those are not too positive. I was hoping some of you have some really good experiences that you will pass on.
This system will require two analog inputs (speed pots), two analog outputs (speed ref to AC drives), about 10 digital I/O (start, stop, limits, etc.), and a small HMI. The operator will only need to enter a move distance (0 to 240 inches with three decimal display) or a rotational move distance (0 to 360 degrees with three decimal display). He will then tell the machine to rotate left or right, or move forward or backward. For safety sake, I will be installing a discrete stop button for both movements as well as an E-stop.
I have used the Siemens S7-200 series PLCs quite a bit and don’t really think I want to use one of them. My main reason is noise. I have had a lot of problems with these units “seeing” noise on the inputs that the PLCs interprets as signals. The built-in adjustable filtering isn’t always enough to overcome this either. Since this system will be going into a heavy industrial environment, I expect electrical noise to be quite abundant.
One of my biggest considerations is, of course, price. As always, I want to keep this as inexpensive as I reasonably can.
Any comments would be appreciated.
Steve
Steve
