Protecting an input field with a Password
NoName
Sep 2003
Domžale
273
Hello.
Is it posible to protect the an inputfield with a password in Protool so that only the operator can change it's contents.If it is possible could you give me some pointers how to do this.
Thank you.
>Ales<
Yes indeed.
It takes several steps, but it is not difficult:
1. Setup a screen where you can setup users and user levels.
You have to insert an object of type Password List.
2. For the input fields that you want to protect you have to change the property Enable ... Password Level from 0 to a higher value.
User level 9 is the highest and is the SuperUser who can create/edit other users in the Password List.
You specify a fixed password for the SuperUser in Protool under System ... Settings ... OP Password.
User level 0 is the lowest, and is normally reserved for items that are not protected.
Ales
It is possible to protect an input field with a password. In the properties of the input field, click on the enable tag, here you can set your password level from 0 to 9. Password level 0 is no password required. Password level 9 is the 'supervisor' level.
I have only done this with TP 27-10 screens, so that is what I am baseing my answer on.
The only password set in protool is the 'supervisor' one. The default for this is 100. To change the supervisor password click on 'SYSTEM' and from the drop-down menu select 'SETTINGS'.
The other password levels (1 - 8) are user defined on the screen itself, but these are lost and have to be redefined everytime you download a new or updated program to the screen.
Hope this helps
Paul
Thank you for your quick reply.I'll get on this right now!I hope that I don't run in to truble.But if I do, I'll check back here.
Thanks alot!!
Hello everyone, been awhile since I've posted..... As the title suggests, using Crimson 3.1 software (Red Lion) I cant seem to figure out if its...
1,713
Hi, Just wanted some thoughts on protecting control and instrumentation from welding damage. We had a PLC and drive fail after some welding work...
5,003
Hi Everyone, Yesterday we encountered an issue where I had a 480V 3Ph 2HP Powerflex 525 blow up. Upon further inspection, we noticed that 10...
21
5,996
Hi, I am currently developing a project and need to know if it's possible that once I download to CPU and HMI no one can upload it and re use the...
23
6,841
We have a PV+400 on our floor that has something quite odd going on. The program hasn't been changed in quite a while, at least a couple of...
5,397
