Hi All
Does any one have programmed 1746-HSCE2 dor SLC 500 before.I found it cery complicated and the manual is not good enough for clearing all the issue.
For example : B3:0/0 is used in the programming example in the manual as a programming eror bit for the module is this i's default when using the module?
- All the counter blocks must be programmed or not(i meean Count rate value block for example)and what happen if i don't programm it.
-how could i intialize the module
-i move the inside jumber to the 5 Vdc position but i can't read 5 V in the module terminals (VDC out& COM)
i know this is may be alot does any one can help me?
Thx
Thx
