Russs
Guest
R
I wanted to monitor an exhaust duct temperature to see what the maximum value was.
The exhaust duct has an rtd. This input is converted via scp to an integer output.
Aside from the compare, which isn't an issue the move statement's location seems perplexing to me.
Initially the move statement was on the rung just before the scp. When trying to move the output word's value to another word it instead moved the analog value (from the rtd input???!!!). When I placed the move statement after the scp the desired integer value was moved.
But isn't the output word supposed to only be the Scaled with Parameter's output value? Why would the inputs value to in that location?
Just curious...
Thanks,
Russ
Just curious...
Thanks,
Russ
