sending ASCII SICS commands Mettler Toledo moisture analyzer
DaiCLy
Nov 2005
New Jersey
I have a situation that I'm trying to resolve. I have a MT HR-83 moisture analyzer communicating via RS-232. I want to get info (moisture & weight) over to a Delta-V. But I am asking from a PLC Point-of-View (SLC..for scenario sake) how to send ASCII-based commands in ladder logic to the scale.
Just a little more background on what I am trying to achieve...reading those afore mentioned signals to DeltaV via RS-232 to Profibus (via MT Profibus converter), and ultimately going into the DeltaV backplane via the Profibus module.
Thanks,
Dai
[email protected]
I guess you are reading thru the built in RS232 port of the SLC - Channel 0.
1. First of all set the comm parameters on both devices matching. Give more thought on the communication format/protocol of the moisture analyser. You can specify certain parameters like the termination characters etc in the Channel o configuration menu of SLC.
2. Store the commands - minus the settings done in the channel 0 configuration - in the string file
3. Use AWA [ASCII Write with Append] SLC instruction to send the string with the commands to the device.
4. Use ARD [ASCII Read] instruction to read the response from the device.
Hope this helps
_______________
Hello, Thanks in advance. How can I send more than 82 characters using AWA or AWT? to Zepra Printer via serial Rs232 communication? Normally I...
781
I am very new to programming PLCs, and one of the first tasks I received was to create a program that creates a socket connection between my PLC...
2,572
I am new to programming in PLC, i have Allen Bradley SLC 5/03. I tried using AWT inst. with data in ST9:0 file directly but in 3 inst. getting...
4,069
:wish:Hello I want to sent the commands attached from PLC to DMX Controller.When i00 command is sent it replies as shown as fig in hyperterminal...
2,067
Can someone help me to find instruction which stores ASCII characters to String data type tag and Is it possible to convert an ASCII string to Hex...
4,636
