showshocka
Hello All. I have this new Panelview Plus 700 with the software. I have bad tag addresses from the old one to the Logix 5000. i'm using Factory Talk ME like the instructions says, to transfer/download the .mer file to the Panelview from th laptop. I can not connect to the 700. I have the usual Ethernet cord hooked up between the laptop and the Panelview. I am in the transfer utility program using RSlinx Enterprise. I made the address for the Panelview 10.10.6.2. my host computer address is 10.10.10.100. i see Panelview 700 at 10.10.6.2 address on the RS Linx Enterprise on the laptop. once i hit download it hangs up for about a minute and then gives me an error the says " the destination selected is not a valid device". That's as much as i can tell you guys right now. can anybody help me out. thanks! By the way the shops laptop is already, and has long been set up for all the plant devices so chances are that i shouldn't have to change anything in the network configs for it. please reply. thanks a million!
