Hi all!
I have got a retrofit coming up. Currently we are using an old Beijer E1151 HMI, which will be replaced by a Siemens TP1500. We use the Beijer as a gateway to send some data by Modbus to a SCADA system.
PLC is a 313C with Lean ethernet interface.
I am looking for an affordable way of achieving the same functionality, we have used Anybus in the past (Can set Lean as PROFNET device, ANYBUS as controller).
Wondering if there are other possibilities/products you guys can recommend?
