jonlaicov
Hello, I'm new to using PLC and am just starting to learn to use the programming logic. I'm using a AB Micrologic 1400 with an HMI using to control a rig motor and log 3 sensors. There is 1 load cell that is used to capture a force that is on / off. the data is collected every minute or 6 minutes. I want to be able to log (very accurately) the peak or max value coming from the load cell. Can someone help explain how to write the logic to achieve this? Just use a A-greater-b function?
Thanks in advance
Thanks in advance
