Using 1783 NATR with Siemens S7 PLCs.
PreLC
Apr 2019
Mars
587
I have S7 Profinet PLCs with local IP addresses in my plant. Can I use the 1783-NATR to configure a 1:1 NAT to get to the plant network?
Regards,
-PreLC
Update, it works! I had to add these to the "custom rule" section under Configuration>Network Address Translation. Otherwise I didn't get a reply back.
80 was for the webinterface, 102 for Profinet.
tcp/udp 102
tcp/udp 80
Regards,
-PreLC
I am currently trying to do the same thing, could you go into a little for detail on how you got this to work? I do not see a custom rule in the NATR setup. Thanks
Can you please share pictures of your NAT table? I'll try to guide you the best I can.
Yes, that is what I wanted.
If you have these rules, and the PLC still isn't communicating, have you set up the gateway on your S7 NIC to be the local address of the NAT? Is your NAT's gateway set to your plant's gateway address?
After this, can you open wireshark and see what error messages you get while using your client software(TIA/S7manager/Ignition etc)? The error messages would have port numbers, which would be used to see which ports further need to be opened up.
Regards,
-PreLC
Fixed! thanks
Thanks for your post PreLC!!
I just made what you recommended (Customs rules) a set Gateway Siemens PLC as the same as NAT (private network), and it is working.
Thanks for your help. đź“š :D
No problem man! If you discover something cool in the future, make a post too!
Hi, I wrote a sequence loop using EQU and MOV instructions and would like to validate that i'm doing this properly. i attached a picture of the...
387
Hi I'm very new to PLC programming and I'm trying to find out if this library (Tc2_NcFifoAxes) is necessary for our task In our case we need to...
54
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
97
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
156
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
304
