Micro850 High Speed Counter Plug-In Module UDFB retentive accumulators
cjarvis64
May 2021
Paducah, KY
Hello,
First post to these forums, long time reader. I have Micro850 PLC (2080-LC50-48QWB) with 3 2080-IF4 plug-in modules and 2 2080-MOT-HSC plug-in modules attached. I am reading frequency from (2) flow meters on each of the high speed counter modules. Rockwell provides a suite of UDFB's for these modules, however the version I am using (RA_HSC_PLUGIN_2) does not allow for the accumulated values to be retained through a power cycle. I found a version that does have a ACCRETAIN input, however for whatever reason it only supports one accumulator. o_O
My question is, does anyone know of a UDFB that someone has written that has an ACCRETAIN input as well as support (2) accumulators? I would just use 4 counter cards but I've filled up my plug-in module space, and moving the analogs to a expansion card isn't an option at the moment. I have attached an image of the different rockwell UDFB's for these counter modules. Thank you.
To anyone that finds this thread with the same or similar issue, I ended up implementing my logic using the embedded HSCE and HSCE_CFG instructions. These give you the freedom to write to the accumulator with the InitAccum input on the HSCE_CFG instruction.
Good day, I have these two written in ladder but cannot get them to work. I am not sure I have them wired correctly. I have two flowmeters going to them sending a D/D- and they are passive so require source. Any recommendations on wiring and some configuration? I am running two flowmeters to one HSC and need the pulse count from each. They run asynchronous so they are not coming in the same time.
I have a square wave being put into the Micro850 input channel 0. I have tried with counting the rising edges with code and with trying the high...
1,928
We have some Pines Benders that we want to upgrade to a digital bend angle, one of them has a CompactLogix PLC with a 1769-HSC module, but I was...
1,820
I can't get the encoder pulses to show up on the function block when I'm in "de-bugging" mode, which is the on-line mode of the software. I...
7,281
Hi everyone. I'm trying to read values from a Loadcell with a 2080-TC card. I know the 2080-TC is a thermocouple card but it reads millivolts that...
241
Hi everyone, I am working with micro850, a proximity sensor (FOTEK, PL-05P) and a 3DOF serial arm robot. I use MC_MoveRelative to control the...
108
