I am running Studio 5000 v32 on a virtual machine. I have successfully built an emulator, downloaded code and ran it no problem.
I am now trying to create a FactoryTalk application. I created this via Studio 5000, and all looks okay. I open the communications for the FactoryTalk Linx node, and add the devices under the Backplane node (same as how it was configured when running the emulator). I then create the shortcut called PLC, select the processor and "Apply".
I open a graphic, create a button, go to Connections, and only System is there. I hit Refresh, but the PLC shortcut is not appearing. Any suggestions? Thanks.
