Micro 820 - HSC
Oliver Micka
Oct 2015
Hlohovec
65
Hi all.
Does anybody know, is Micro 820 ( 2080-LC20-20QBB ) have a directly HSC inputs ?
I would like connect two "encoders" to the Micro 820 and read data from this.
I found video on a Youtube but that video is only for Micro 850 ( Micro 830,850,870 ) but not for Micro820.
Currently i cant find any documents were have info is Micro 820 supported HSC inputs via terminals. ( without plugin module )
Check the Input maximum speed. Against your requirements
The HSC is 150khz by memory. But the standard input max spd is 30 kHz.
- I might be wrong. It’s a long time for me
MICRO 820 PLC - 2080 MOT HSC - Jencoder J-15S-SL Above plc, add on module and encoder are using to configure one paper cutting machine...The...
3,902
I’m running a micro 820 to measure a tank level, then turning on equipment at certain levels. I have an analog input (4-20) that I’m storing and...
317
Hi All, I came up with this for ramping the PWM pin on the micro 820. I'm new to ladder logic so I am not sure if this will even work? Once...
380
The micro 820 is visible in RS Who when I configure my Ethernet to capture the random IP. I am getting an error when following the steps below...
1,021
