Weintek HMI_Problem during using “ftp” command to open files
AB2005
Nov 2006
Lahore
318
[FONT=&quot]Hi;[/FONT]
[FONT=&quot] [/FONT]
[FONT=&quot]I have Weintek HMIs connected with an Ethernet network. Usually I do upload the data log files by using “ftp” command. By using my Laptop (Windows10), I do type the address (like ftp://uploadhis:[email protected]) and press enter and system opens the files of selected HMI.[/FONT]
[FONT=&quot]Yesterday, I tried to open the files of an HMI by using same command but system opened “Open With” options (Chrome, Fire Fox, Microsoft Edge etc), unintentionally I selected FIRE FOX and ALWAYS and found that system tried to open a web page but failed. I don’t know how to setback this setting. Do you please help? [/FONT]
I am following, I am having a similar problem.
Sounds like you set the default app for ftp protocol. Can you verify this in Windows settings (see pic)?
If that's the issue, unfortunately Windows doesn't let you remove individual associations easily. You can either use the 'reset to defaults' option (with the side effect of resetting all your file associations), or you can edit the registry to remove the association.
If instead you've just associated whatever file extension your HMI files use, then there's better options than registry hacking. I don't know anything else for protocol association though.
[FONT=&quot]Default setting has been changed but yet when I type the address and enter, OPEN WITH options pop-up rather opening of files. This is specific only with one HMI (MT8150XE) while other HMIs files are opening by FTP.[/FONT]
I'm trying to upload a program from the aforementioned HMI but I've failed so far. I have an EasyBuilder pro and using Ethernet cable. From the...
7,999
I am using M340 PLC and using Ethernet Crossover Cable to connect it to Weintek MT8100i HMI. I have defined the protocol in Easybuilder 8000...
2,727
I am using Weintek MT8100i HMI and Schneider Modicon M340 PLC. In easybuilder file, I have Defined the PLC as Schneider Modbus TCP/IP type. Now...
16,567
I have been working with a PLC which has three WEINTEK MT8000i TouchScreens and a computer with an ICONIXS SCADA and an OPC server. Everything is...
3,168
Hello everyone, I am currently facing a challenge while trying to connect two Weintek HMI units with a Mitsubishi FX2N PLC. When connecting a...
536
