My recent PanelView Oxidized Screen Repair experience
JaxGTO
Apr 2009
Kalieefornia
1,074
My customer had an old PanelView 1000 in a system that is going to be pulled out next year. The PV screen became oxidized so bad you could barley see anything. So while the system was down I decided to try and fix it. I purchased a Meguiar's Headlight Restoration Kit from Auto-zone.
First I taped off just the screen so I wouldn't damage the function key area. I also removed the control board and taped up all of the vent hole to help keep out any water from getting in the screen.
I then used the 1000 grit sand paper disc by hand. Keeping it wet at all times. This worked great for getting off all of the oxidation. The screen was very hazy still from the sanding but I was confidant that the next grit and polish would get rid of those scratches.
Then I used the 3000 grit disc. Again keeping it wet. I used that by hand as well sanding very lightly until the whole thing look uniform hazy.
Finally I used the yellow polishing wheel in my drill at a very low speed, maybe 800 RPM. Using the PlastX polishing compound twice.
Well I couldn't believe the great results. The customer thought I bought them a new screen.
I also used the Headlight Sealant using the included applicator sponge. After letting dry it looked even better. The sealant really smooths out any remaining scratches.
And after all that the touch still works perfectly.
I attached a before and after.
Is anyone aware of any recent Rockwell Software security issues that require version upgrades to mitigate? I'm talking over the past 2 months.
731
I have 6 Red Lion DSP units displaying PLC strings and data to 6 industrial LED screens. After sending the .cd3 file from screen 2 to screen 6...
1,055
We have just recently had an "outside" organisation upgrade our AB SLC PLC with a Controllogix. In doing so they have changed all of the messages...
1,817
Here is my recent experience using the Zebra AOI for printing from the PLC. Please do not ask me for my PLC or template files as they are the...
12,395
Hi guys, I have a local station SCADA program that requires a daily automatic 1 page printout of the most recent alarms from the Alarm and Event...
3,437
