2080-LC30-24QWB - firmware download failed
Oliver Micka
Oct 2015
Hlohovec
65
Hi all,
I have problem with this PLC.
I have Micro 830 ( 2080-LC30-24QWB series A ).
Yesterday i tried download PLC code in to the PLC,
CCW wanted to upgrade firmware on this PLC,
I did chose - OK,
Original FW was 6
I chose a new : 12
During the process "downloading firmware" CCW in the half proces CCW freeze and showed me "connection failure" and after this failure CCW show me loss communication with the PLC.
If i tried repeat this process CCW showed me fault -- "can´t connect to the PLC", then i did try " disconnect power, wait a half hour and connect power again " to the PLC.
After i connect the power i have same status " Flashing Fault LED".
RsLinx see this PLC only through VBP-1 , and if i "click" to + on the station, nothing found..
I try use ControlFlash (v15.04) to re-flash firmware, but if i chose a correct type of PLC "2080-LC30-24QWB/A" and chose direct way to the PLC via RsLinx -> VBP-1 -> 08.Micro 830, ControlFlash showed me " device is different, please chose a correct device"
( i tried chose 2080-LC30-24QWB and 2080-LC30- 24QWB/B -i have same fault - device is different, please chose a correct device" )
I think, my PLC is "Bricked" but i don´t know, how can i "Unbrick".
Does anyone know, what is the better solution for this fault?
I found a several similarly situation, but nothing helped me.
CCW - 13.00
RsLinx - 4.20.00 - CPR 9 SR 12.0
ControlFlash - 15.04
Note: I tried use a DF1 port ( cable 1761-CBL-PM02 ), but if i connect to the RS232 port in the PC, nothing gonna happen.
DeviceManager dont showed me any info for new device on COM port.
The only one way, where my PC react to the connected device ( my PLC ) is only throught USB cable.
I would be very grateful for any help.
Good day, I have a micro 850 with a 2080-MOT-HSC that is being fed by two flowmeters, Schneider Electric using IMT31's as converters. They are...
458
I'm trying to set up a ring counter - one that transitions from 3599 to 0 (and 0 to 3599 in the reverse direction). My counter insists on...
359
hello, I have a Maple Systems HMI5103L currently programed and running in conjunction with a AB 2080-LC50-24QWB. everything works fine data is...
721
I have run into a problem with my first time installing a 2080-OF2 module on a Micro820 and have a hunch that the module itself - brand new out of...
930
Hello, I just downloaded the RA_HSCPlugIn UDFB from Rockwell's official page and but when I try to open it inside CCW it asks me for a password...
517
