PID and PIDE instr. in ControlLogix
jambrich
Jul 2003
www.presov.sk
Hello!
I would like to as if anybode have some experience
with converting PLC5 programs to Controllogix.
I have convert PLC5 PID instruction to CLX.
Now I have PID instruction.
Q: Is it possible to "convert" this instruction
into PIDE? As I have read in manual PIDE uses
different algorithm. I am sure that it is necesary
to putt different constants for P, I ,D.
BTW: can I convert PID in plc5 and PID in CLX
ande replace controllers? The times of PID
execeution will be the same in CLX as was in PLC5.
Thank you!
I would like to know if somebody has real
experience with such a substitution.
jambrich
I have a PID instruction in the ladder logic with tag name pid1 I was trying to follow the youtube to create the PIDE faceplate, however, the...
1,179
In control logix I have come across a few programs where the PID is setup in 1/sec, but most are 1/min. Where would this configuration be and when...
1,360
Hi everyone, I have a project start up coming up in the next few weeks that I have 4 PID routines in my program. I have never used PID in a...
3,877
Hi, I am working on control level project using PLC 1756-L62 (Rockwell). I put the same parameters on a MATLAB PID and PIDE of Logix5000...
1,649
When using a PID you have access to a bit .MO What is the equivalent to .MO in the Pax P_PIDE Thanks
4,575
