How to enter the right parameters of PID instruction in RSlogix 500
leoxdragon
Oct 2009
Ha Noi
Hi everyone
I'm trying to setup an PID loop using SLC 5/03 processor. I'm aware of the PID instruction basically. However, I found problem in entering the parameters (gain (Kc), reset (Ti) and rate (Td). It states that Kc must range from 0 to 3276.7, Ti must range from 0 to 32767 while Td must range from 0 to 327.67 to be accepted. So I'm confused. Do I have to convert my own Kc, Ti, Td to these other parameters defined by AB? If I have to do this, what is the right function to convert?
Here is the setup screen
pls help me with a particular set of following parameters:
Kp =0.0562
Ti = 66.67 (sec)
Td = 0
Thanks in advance
See picture below for what you can do. Others, I'm sure will have comments on how you came up with your numbers.
Note: note 2
Thank you, Micky. Sorry for late reply. It's quite clear enough. I also found one like this in the helps notes when I checked it more carefully. Thanks
functions and application of PID
Hi I'm new to this field can any one post a link or explain the functions and apllication of PID . (with simple terms please ). rather i would like to know on wat terms these parameters are set with an example
aec,
Look at the "PID Controller" article on wikipedia and links there.
For academic study, there is an excellent text by my former professor Dr. Carlos Smith, "Principles and Practice of Automated Process Control, 3rd ed.".
thank u :)
thank u all for your time and response . link by mickey will help me more I think .
Hi Everyone, We are getting an error window whenever I opened the Factory talk asset center Application as "The Database size is critical level...
336
My system are taking data from RHT sensors, around 45 points. Now I want to make a function in which, if the data is #BAD or 0 in values for all...
477
*VMWare vCenter Converter Standalone version 6.3 & 6.4 Hello Experts I want to convert my current physical hardware machine to a virtual...
1,620
Hi, I have to create a log file in Ftview SE when a setpoint is changed on a tag and conirmed with the enter key. Can anybody help please?:lolis:
1,106
628
