TIA Portal v17 vs S7 PLCSIM Advanced v4.0
IdealDan
May 2017
MA
480
Hi Friends,
I tried using TIA Portal v17 with S7 PLCSIM Advanced v4.0 but no luck.
Has anyone here tried with success?
Could it be because I'm using the trial versions of both?
Also, could you please share how you configured both to work?
Thanks in advance!
Trial version of Portal is full featured. Don't recall how trial of SimAdv is licensed (if there is one) but Siemens does Nag windows or temp licenses or something, never missing features in trial.
I didn't do anything special (compared to v16) to get it to work. Is PLC Sim Advanced running correctly or giving you error messages.
Did you enable simulation for your project? What error message are you getting that it isn't working?
Thanks again.
Yes I enabled simulation in TIA.
PLCSIM advance Panel opens, but created controller instance does not start up.
Thanks again.
did you try starting it up yourself?
what error message do you get?
should be some kind of pop up or a message in your windows notifications or something.
Yes bro, thanks for your support, here is an attachment of the error pop up.
Oof, that's a doozy of an error.
I'd say kalabdel's idea of uninstall/reinstall is probably a good one, and if that doesn't do it, you need to call tech support.
What CPU and how much RAM do you have on your PC/laptop.
The error message is clear-ish, the simulated PLC is taking too long to start working and thus generates the timeout error, check CPU and RAM usage when you try to start it up.
+1
TL;DR
This error comes from a statement something like this:
Code:
assert pRet && m_is_allocation_allowed;
In the code, specifically in some C++ file called Package...oxy.cpp, the value of variable pRet is 0 (NULL), and/or the value of variable m_is_allocation_allowed is 0 (NULL). If either of those is 0, the programmer decided the code could not continue and the best thing to do was to throw an error/exception. That event is not handled ("caught") further up the call chain, so the program crashes and the RunTime displays that popup.
Without source code no one is likely to divine the reason for this failure. Code is more like electronic ignition than a distributor; it needs certain assertions (assumptions) to be true to run and cannot limp along if things are "close;" the programmer chose to have the program crash rather than try to continue with this particular failed assertion.
That said, here is some speculation (in increasing amounts as you read).
A failed assertion is usually something, which the programmer expects to be true, that actually evaluates to false i.e. an unexpected condition, that indicates something is rotten in the state of Denmark.
This particular problem seems to be about allocating something.
The name pRet sounds like a common-ish abbreviation for "pointer Returned" or "pointer to Return" e.g. a pointer to memory, e.g. memory allocated to contain an instance of a class. Typically this is done with a statement like this:
Code:
pRet = new ThingClass(arguments);
where ThingClass is the identifier for the particular class that needs to be allocated; the name of the source file ends in "oxy.cpp;" I wuold guess that oxy is the end of the word Proxy; this is a software simulator of some hardware, so the are probably many functional proxies in the package. Arguments, if present, are used to assign values to members of the class e.g. size of a buffer. If the required memory could not be allocated, e.g. if the desired buffer size is too big, then an invalid pointer is returned; an invalid pointer has a NULL, or 0, value. The likelihood of a single memory allocation failing is small in this day and age, so pRet would not be zero unless a bad size parameter (too large, or negative) were supplied, or the code got into an infinite loop and continued allocating such instances until memory was exhausted.
The other variable in the assertion, m_is_allocation_allowed, probably means what it says. Typically something like that is an int (integer) representing a boolean state, with a value of 0 meaning false and any other value meaning true. Determining why it would be 0 (false) would involve guessing why it exists in the first place: the trial version is supposed be fully functional, so is it possible the trial period has expired, although I would expect something before this obscure error would take the opportunity to more clearly state the base problem and ask for money to continue; or could it be temporarily false while another process in the package is initializing or in some other state, as suggested by tdoa; who knows?
Anyway, OP is in the US, so Siemens tech support is hungrier and maybe more likely to actually provide support. The variable names are in English, so maybe the original coder is local as well, if it gets that far.
Maybe the current machine is DLL hell as far as this app is concerned. Could this be attempted on another machine, or on a clean windows install on a VM?
105
Hello forum, I wanted to install Step 7 TIA Portal V17 on my laptop (Win10 64 Bit). Unfortunately, I am getting this (error:14667)...
654
Hi everybody, I have this variable (Activate1) that should be set when I activate a button from the hmi, but instead is only set as long as the...
1,256
Hello all, I am working on a project using an s7-1200 and tia portal v17. The project is for stepper motor control for a SMD23E2 motor. I am...
5,396
Hi all, I am starting a project with motion control and currently have a few stepper motors that I want to get working with a S7-1200 CPU. The...
4,227
