No received data open communication with S7-300 and Hercules terminal.
mulderm
Jun 2003
Netherlands
298
Hello,
I use open communication with a Siemens 315-2 PN/DP and the terminal of hercules, follow by the link https://www.youtube.com/watch?v=p4mmDP-f38Q
Now the TRCV block is functioning, when I send "H" the plc will received this.
But the TSEND block is not functioning, I received no data on the hercules terminal.
Can anyone help me for this problem?
See also the attached files.
Greetings mulderm
The TSEND REQ input needs a rising edge to send the data. A constant true after connection setup won't work. Have you tested it with a rising edge on M30.1?
Hello Thomas, yes I use this.
Now one Charakter is oke but a few charakter not.
I think for filling the data in the TSEND block it must be a pointer for the s7-300 isn't?
But how I fill in?
I get message 8092 when I use this for the TRCV function for example so the data is not correct?
I use TIA V13.
The TSEND block has a parameter LEN, wih you can see when you click on the triangle.
I believe if you have an array of char, you can enter the array without the bracket and index as DATA parameter, and specify the lenght with the LEN parameter.
On a 1200 you can pack the variables of different types into a struct, and enter the struct at the DATA parameter and set the LEN.
Use "db_Receive_2".Receive as parameter.
Remember that the client hast to send 2 bytes before the TRCV signals when new data has arrived.
Thomas,
Many many thanks!
That was the problem, now I get the pointer to show it.
It works!!!!
Thanks for the fast response, I appreciate it.
I have two PLCs connected by gigabit ethernet over fibre, PLC0 has NOE0100 ethernet module IOscanning PLC4 with 100ms repetitive rate. both are...
4,469
G
hi there, i m today in a position where i require to convert protocol. the reason is i m working on a project where one device talks in modbus and...
9,894
Were those the only files? Megabasic files have the suffix .bas You can probably get along without PCOP. Termf is sufficient to do whatever you...
184
I received this by PM. I prefer to keep the discussion on the forum. Hello ! I managed to connect to PLC GE 90-30. I don't know the Proficy...
1,161
I just got this via PM I prefer to keep the discussion on the forum. Can you be a little more specific? What is the nature of your trouble? Are...
671
