Combine Alarms FactoryTalk View ME
Psymon
Jul 2004
Wisconsin
111
Is there a way to combine the alarm configurations from two separate FactoryTalk projects into one? If I import one over the other it just erases the previous config and replaces it with the recently imported one.
You can use Excel. Just copy/paste tables from the PV applications to Excel, combine them, copy/paste back.
I tried that, the triggers and messages all have unique identifiers that would otherwise overlap. In the XML file they all have a T1, T2, T3, etc. identifier for the trigger and an M1, M2, M3, etc. for the messages.
It's a bit more of a hassle to learn, but I would highly recommend using the XML export/import feature.
If you use the import/export to XML feature:
You will have to re-order the trigger (T1, T2,...) and the message (M1, M2, ...) identifiers in Excel, making sure you have no duplicates. It doesn't matter that you change the T or M identifiers as along as they stay paired together.
If you want to use the copy/past method:
Create all of your triggers first. There is no copy/paste so you will need to do that manually. But you can open FTView Studio twice (two instances) one for each project. Flip back and forth as needed for the alarm trigger information.
You can multi-select the message rows from within FTView in the Alarm editor. That will paste right into an open Excel sheet. Make your changes, additions then paste back.
If you are adding more rows, you will need to have a bunch of empty rows already in the Alarm Editor. I think you can just hold down the Insert key to do that.
Hi; I have installed Weintek HMIs at different machines. I have configured data logging and HMI logs the data in a file having extension...
1,304
1,207
I am getting data from a modbus device and I need to combine 2 16 bit N registers in to 1 32bit L register. I have tried a CPW N242:2 -> L245:0...
2,158
Hello Everyone, I am working on CCW 9.0 software with PLC Micro820. I am communicating with Energy meter over Modbus RTU. I...
4,112
How do es a person combine two words of data into one. N7:0 and N7:1, High word and Low word, 1234 and 5678 and get 12345678.
2,286
