Hi all
I'm trying to call an AddOn Instruction from another AOI. The AOI (wich name is Swap_Bytes) that must be called has only an Input INT parameter and a Output INT Parameter. It swaps the 2 bytes of the input variable and save the result in the Output variable
in the calling AOI I tried many syntaxes, but I'm not able to make it works:
the two parameters that I use calling the AOI are INT variables...
any suggestion?
thank you
Code:
Swap_Bytes(St_Status_W0,St_Status_Word_Array[0]);
Swap_Bytes(Swap_Bytes,St_Status_W0,St_Status_Word_Array[0]);
(this is what manuals suggests, but debugger tell me "undefined tag:Swap_Bytes")
St_Status_Word_Array[0]:=Swap_Bytes(St_Status_W0);
any suggestion?
thank you
