Hello everyone,
I have recently started a new project using ST in Studio 5000.
Previously, I have programmed in ST in Siemens. As i was writting my code in Studio 5000 i came across the following problem with CASE_OF
// In Siemens i had the following code:
CASE #req OF
#MANUAL: //constant as a selector variable
expressions.....
END_CASE
It works perfectly fine
// In AB Studio 5000 i have written the following code:
CASE G.Req OF
C.MANUAL: //constant as a selector variable (shows error here)
expressions.....
End_Case;
The above code returns an error. How can i use C.MANUAL as a selector for my case structure.
Is there a way I can use the constant as a selector variable or does it support only numbers?
Note: Both G.Req and C.MANUAL are of INT data type
CASE #req OF
expressions.....
END_CASE
CASE G.Req OF
expressions.....
End_Case;
