PanelView Plus 7 Alarm List Message Display is Wrong
lkkplayer
Dec 2020
Kaosiung
I use
PanelView Plus 7 Graphic Terminals
Model: 2711P-T10C22D8S-B
PLC: Compact Logic 1769-L36ERM
Tag ER[4].8 -> ON, the message is "1046 Abnormal Load Location"
I encountered a strange phenomenon
When ER[4].8 -> ON, the alarm list show "1046 Abnormal Load Location" is right.
But ER[4].8 -> OFF, the alarm list show message is wrong in two Graphic Terminals.
The Alarm time is the same, but the message is wrong.
I don't know why happen?
How to solve this problem?
It may happen if any other error bit is triggered after you acknowledge the ER[4].8 or if there is already an error bit which is active.
Check your program code to see if there are any active error bits and subsequently, check in the HMI Alarm List the corresponding Alarm Description for the particular error bits for both the terminals.
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
133
Hello, I have followed the "On_board Audit Demo" sample in FactoryTalk View Studio ME to add the functionality of exporting the Audit, Alarm, and...
1,139
PanelView Plus 7 Perf I would like to upload the fault history from the panel to the PC, if it is possible to transfer the file to CSV format or...
803
First time using a panelview. I have all of my alarms mapped to bits of dints. How do I get the alarm panel to popup when an alarm happens...
2,122
Hi guys, i am working on a project using PV+, there is a problem for the alarm history display: 1. first, to clear the alarm history. 2. create a...
2,565
