Crimson 3.1 Emulator
garethmjohns
Apr 2019
UK
I'm late to the party here but have changed PC's and started a new project for a graphite display with crimson 3.1. I have now tried to use the panel emulator and the option is greyed out. I've done some reading and the only thing I have come across is one thread suggesting the function is no longer active but I find that hard to believe.
Is there a global setting I have missed? On 3.0 it just worked from the outset.
The emulator hasn't yet made it in to Crimson 3.1, so it isn't currently available. Originally there wasn't even a button for it, at least we do now have a button even though it doesn't yet do anything.
With a Graphite, you can still develop in 3.0 and use the emulator. Then use 3.1 and import your work. You can do this with other hardware too, even if your target platform will end up being a CR series, but you will have to start with a graphite (of the same size or close to it) and then do a hardware conversion before your completed work can be transferred to a CR series HMI.
I do miss the emulator. It is very useful especially for testing scripting, before you have an HMI. I hope they have plans to make this work again.
Hello Kind Folks, On my Red Lion Crimson, the "Send to Emulator" box is greyed out, and thus I'm unable to run the emulator. Has anyone run...
3,457
Hi Experts! I am trying to get a Redlion Crimson 3.0 HMI to talk to a Rockwell Emulator. I imagine I'll have to use OPC DA. Has anyone done this...
1,176
Using a Raw serial driver in Crimson 3.0 I'm trying to test some code. I've written some code to transmit so ascii characters with PortPrint() and...
1,091
Hi there, I'm very new to all this and I would like to ask for a bit of advice. If possible, can someone please point me in the right direction...
1,177
Hi, Has anybody found a way to make RedLion Crimson 3.0 Emulator "talk" to Rockwell Studio 5000 Emulate (within the same PC, running Windows 7...
1,952
