plc storereviewsdownloads
Reply
Thread Tools Display Modes
Old July 27th, 2016, 02:49 PM   #1
Levi G
Canada
Levi G is offline
Connecting to Panelview 800 with CCW
Hi I am trying to connect to a panelview 800 (2711R-T7T) using CCW version 9,with crossover cable going from my pc to the panelview . When I try to download to the Panelview, RS Linx pops up and it shows the Panelview 800 (I can also ping it )but when I click on the Panelview in RSLinx and click ok the output in CCW shows "device connection failed".
What might I be missing here?
I have attached a screenshot from RSLinx.
Old July 27th, 2016, 03:09 PM   #2
nhatsen
Venezuela
nhatsen is offline
Can you download to the PV via USB cable? If the answer is yes, maybe you'll need to do a factory reset on the PV to solve the problem.
__________________
"If you can't solve a problem, then there is an easier problem you can solve: find it." (George Pólya)
Old July 27th, 2016, 04:18 PM   #3
Levi G
Canada
Levi G is offline
I have been able to load program with a usb stick. Have not tried the cable, how do I configure the driver for usb cable? I think the web browser function is now disabled on the ones with firmware higher than 3.011. so I would have to connect with CCW to make changes
Old July 27th, 2016, 04:54 PM   #4
nhatsen
Venezuela
nhatsen is offline
TN 455067 (Access Level Everyone) PanelView Component/PanelView Plus USB connection with Windows 7 64-bit:
https://rockwellautomation.custhelp....il/a_id/455067
TN 788054 (Access Level TechConnect) Download to PanelView 800 using USB cable connections:
https://rockwellautomation.custhelp....il/a_id/788054
__________________
Old July 27th, 2016, 05:10 PM   #5
Levi G
Canada
Levi G is offline
Thanks for the info. I will give this a try
Old September 3rd, 2017, 04:43 PM   #6
Scott_Helton
United States
Scott_Helton is offline
Resolved?
I am having the same issue. I cannot connect via Ethernet, so I set up the USB and get the same result. I can see the PV800 in RSLINX, and I can ping it. But when I try to connect, I get the "device connection failed" popup. Any ideas? I have also been able to copy the .cha file from the PV to my USB FlashDrive...but cannot do anything with the .cha file. I do not have a CCWSLN file for this PV.
Old December 19th, 2020, 04:29 PM   #7
AndreLuizCV
Brazil
AndreLuizCV is offline
PanelView 800 - Rslinx error
I was having problems to visualize the PanelView 800 over Ethernet at Rslogix.
I could make it appear doing a out-of-box reset.
https://rockwellautomation.custhelp....US#__highlight
Old April 8th, 2021, 06:29 PM   #8
willbird
United States
willbird is offline
This worked for me as well. Was driving me crazy LOL.
Bill
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Help with Micrologix 1200 and Panelview 800 oncewaslost LIVE PLC Questions And Answers 5 July 4th, 2018 09:36 AM
AB PanelView 800 iggy LIVE PLC Questions And Answers 3 June 16th, 2016 06:50 AM
Connecting a Panelview and Micro 850 to a Network perkins4 LIVE PLC Questions And Answers 2 October 1st, 2014 04:45 AM
Panelview component app. modified in CCW run error. marcinski LIVE PLC Questions And Answers 5 February 5th, 2014 09:56 AM
Connecting to a Panelview Plus via PC Rob Smith LIVE PLC Questions And Answers 6 April 17th, 2006 11:57 AM
