Fluttering outputs
khewes
May 2016
New Hampshire
123
Hi everyone,
I am using micrologix starter lite for an Allen Bradley micrologix 1000. I have not had the chance to connect to the PLC yet. In my ladder logic, my outputs are unstable and flutter on and off after a TOF timer. When run via advanced hmi, the outputs as lights do not remain on for the designated time, but instead turn on and back off continuously until the time is up. Any guidance would be much appreciated, thank you.
Attached is the zipped RSS file thank you....I apologize for the poor commenting I am new to micrologix, I just figured out how to add rung comments
We would have to know what is going on in your HMI.
But one problem I do see is you are "Double Coiling" the outputs ( controlling them(same output) in different rungs). The last rung always wins.
thanks mickey, yeah i was just thinking that the test all might have been messing it up. I think maybe a memory address would help instead of having an output address at the end of each rung. does that sound like a possible solution to "double coiling"?
Also I am not sure what you mean by what is going into my HMI. My HMI is currently just one single screen with an activate button, stop button, four individual light test buttons, and one test all button. As well as four pilot light outputs
Hello all. I have a few SLCs in my plant and of late we've seen a weird issue: The system will be running normally and then randomly the outputs...
125
Problem: Our PLC can only output 4-20mA, but the actuators it needs to control, modulate based on a 0-135Ohm signal. Buying 4 or 8 individual...
304
Does anybody know how 'timestamp output' functionality internally works in a controller? I do not mean the instructions you use as a programmer...
72
Hello, I am stuck on trying to get an ArmorBlock, 1732E-16CFGM12QCR to respond to EIP outputs. My PLC is Panasonic FP0H-C32ET. I Registered the...
155
Hi all so i have a robot project im working on were i need to set the layers. using the hmi screen i would like to use the numeric data display to...
867
